On Sun, 14 Nov 2004 22:27:05 +0100, Joris Dobbelsteen spoketh
The WAP54G is just a simple wireless network hub. It doesn't have any DHCP features or packet filtering features. The AP itself can be configured as a DHCP client, but it does not do any routing or DHCP relaying. If you need to keep your WLAN on a different subnet, then you'll need a wired router (or a switch that'll do VLAN routing) that can do the DHCP relaying for you.
The WAP54G supports WEP and WPA with Radius authentication. As for policies, there's a million options, what are you specifically looking for?
Expect to get around 20-30 Mbps through the access point...
Lars M. Hansen
