router with ipv6
anyone know of a wireless router that provides ipv4 and ipv6 support.
looks like my linksys (WRT160N) only provides ipv4.
mikeyhsd
According to Google (several are wireless) you could also check the Phase1/Phase2 lists at
Bob
If your router is a revision 1.0, 1.1 or 3.0 you can upgrade it using the free dd-wrt router software. According to the Features list as shown below the dd-wrt software does support ipv6.
Take it slow and do the steps in the order the software instructions show so you don't "brick" (make it non-functional) your router. I believe on your model you have to load a boot version first, then flash to the dd-wrt designed specifically to work with your router.
The main link to the web site is
you go to the Router Database at
and input your model WRT160N it will lead you through finding the right software. Click on your model and it should take you to the software download page for your router.
Good luck.
GlowingBlueMist
Just wondering what your situation or scenario is that requires ipv6 support ?
ps56k
One that I have heard about is Windows 7 by default requires a router that supports ipv6 if you want to create a Homegroup and connect say a wireless laptop to a wired PC and share resources. True there are registry hacks that can combat this but with the right router it's not needed. Check out this link for more info on W7 Homegroups and ipv6:
GlowingBlueMist
have NO specific NEED at this time.
keep seeing warning that IPV4 addresses are about exhausted.
just trying to get prepared.
mikeyhsd
thanx, will do some further research.
mikeyhsd
Meanwhile, at the alt.internet.wireless Job Justification Hearings, mikeyhsd chose the tried and tested strategy of:
It feels like there have been warnings about IPv4 exhaustion on a monthly basis for the past ten years. Apparently in China, some internet users are behind many layers of NAT, so we'll know we've hit a crunch point when ISPs are doing that on a widespread basis in the west.
alexd
If you were a Comcast user you could get involved in their trials.
Bob
Cisco do IPV6, obviously.
For home DSL users IPV6 may be a long, long way away as a matter of necessity. I suspect that the major ISPs are already all geared up for it internally but I am not by any means sure.
bod43
do use comcast. but for nothing but what is absolutely essential.
mikeyhsd
Well, let's see...
used to say there were 3706453504 IPv4 addresses usable (RFC5735 added two more /24 reserved ranges, and we're down to
3706452992 now). Ignoring RFC5735 address space, we have:
Date Networks IPv4 addresses Percent
12/31/1982 1813 307452416 8.295 12/31/1985 1997 360680960 9.731 12/31/1990 7907 730298112 19.703 12/31/1995 44077 1374740706 37.090 12/31/2000 54938 1698877890 45.836 12/31/2005 72599 2246643418 60.614 12/31/2007 83944 2566145180 69.235 12/31/2009 99556 2986843144 80.585 01/15/2010 99798 2994785288 80.799
I suppose some might say "end of the internet in sight - films at 11". I know you're aware of RFC1918, but RFC1917 may be interesting reading.
1917 An Appeal to the Internet Community to Return Unused IP Networks (Prefixes) to the IANA. P. Nesser II. February 1996. (Format: TXT=23623 bytes) (Also BCP0004) (Status: BEST CURRENT PRACTICE)
Note the date. The first IPv6 addresses weren't allocated until August 1999, and even now there are only 4153 IPv6 networks world-wide.
I'm not sure that I'd pick on China (or India) - as both are comparatively undeveloped, but multi-layer NAT doesn't sound very likely. China didn't get the Internet until 1990, and at year end for each year, they had:
1990 1 256 2000 450 13276672 1991 2 512 2001 542 21803520 1992 7 197632 2002 599 29487616 1993 17 396288 2003 694 41646592 1994 50 517376 2004 829 60339712 1995 143 1256960 2005 968 74348032 1996 198 2966016 2006 1157 97990144 1997 240 3769856 2007 1384 135281920 1998 331 5424640 2008 1551 181776640 1999 375 7570944 2009 1695 232446464
As of 01/15/2010, that was 1700 nets and 234183168 IPv4 addresses for a population of ~1.3e9 people (about 1 address for every 5 people) while India had 695 nets and 19420928 IPv4 addresses for
1.1e9 people (about 1 address for every 57 people), compared to (examples) South Korea with 748 networks and 77822464 IPv4 addresses for about 48e6 people (~1.6 addresses per person) or the UK with 3916 nets and 74332504 IPv4 addresses for about 60.5e6 people (~1.2 addresses per person).
Old guy
Moe Trin
NOTE: Posting from groups.google.com (or some web-forums) dramatically reduces the chance of your post being seen. Find a real news server.
I see a significant number of complaints from *nix users reporting slow browser connections. When they put a packet sniffer on the system, they see their system asking the DNS server for an 'AAAA' record (hostname to IPv6 address) and the server ignoring them. After a few seconds (up to 30), their system asks for an 'AA' record (hostname to IPv4 address) and get an almost immediate response. This is a well documented problem:
4074 Common Misbehavior Against DNS Queries for IPv6 Addresses. Y. Morishita, T. Jinmei. May 2005. (Format: TXT=13073 bytes) (Status: INFORMATIONAL)
and you'd think ISPs would have pulled their finger out by now...
Old guy
Moe Trin
Please don't post in HTML. Thanks.
On Thu, 28 Jan 2010 18:02:48 -0600, "mikeyhsd" wrote in :
John Navas
On Fri, 29 Jan 2010 21:12:35 -0600, snipped-for-privacy@painkiller.example.tld.invalid (Moe Trin) wrote in :
Nonsense.
John Navas
Google Groups more likely. If only because so many people (such as myself) have blocked GG entirely because of the spammer problems.
Kurt Ullman
On Sun, 31 Jan 2010 12:27:38 -0500, Kurt Ullman wrote in :
Nobody cares that you and a few others choose to engage in such silliness.
John Navas
Trolling?
Plenty of us block google with a higher proprity retrieve on specific posters.
It reduces traffic by about two thirds, mostly spam.
Christopher A. Lee
Glad to have another Comrade in Silliness. Apparently JN cared enuff to reply.
Kurt Ullman
It wasn't a rhetorical question whan I aid "trolling?".
Christopher A. Lee
