Hello All!
I have a wireless router (NETGEAR 814v2) working with a cable connection (DHCP server), serving two Macintosh computers (system 9.0 one, and 10.3 the other), since the beginning I found the router connection erratic, sometimes working and sometimes not, with frequent cuts. After some investigations I discovered that the router only connects when the IP is within a certain range, close to the router address (192.168.x.x); when the IP is other number, like 169.254.32.xxx or 217.70.66.xx the router can't connect or cuts connection when IP changes to a number different from 192.xxx.x.x My problem is that I have a dynamic IP (fixed IP is too expensive for a home user) and my ISP changes IP too often (5 times a day or even much more). There is still some hope for my wireless Internet? I send thanks in advance to anyone who can give me any idea, since I am lost, being nothing like an electronics expert, and just to explore the cause of my problem I had to spend hours and hours?
Thanks for your attention to this message.
