Is there any router than can handle Virgin Media 20meg service
- posted
15 years ago
Sure, but not being in their service area, it's difficult to be sure. The local cable modem service is "burstable" to 15Mbits/sec. All but the very slowest routers can handle that. See the list of routers and the WAN->LAN thruput at:
One catch is that if you are using some of the CPU cycle gobbling features in the router, such as a VPN termination, complex filter rules, or local USB storage, it's going to be slower than what the tests indicate. In that case, you should do your own testing using IPerf. See my examples at:
and correction at:
Also search this newsgroup for "IPerf". If it works on a test setup between to computahs, you should have no problems using it with a
20Mbit/sec service.Cabling-Design.com Forums website is not affiliated with any of the manufacturers or service providers discussed here. All logos and trade names are the property of their respective owners.
