This Roku 2500x I've had since 2013 has always had problems streaming news and most PPV movies on Vudu. The news is on the main menu not an added app. Netflix, Hulu, Acorn, PBS and Some others don't have problems. It got somewhat better after changing ISP appx 15 months ago.
It takes so long to load I'm wondering if this Roku is the problem, instead of internet connection. Most speed test are at least 6 Mbps. I've called tech support at ISP several times and they say its not caused by the connection.
I wonder if its the Roku?
If I buy another one and it isn't better that'll be frustrating too.
Does anyone have any suggestions?
Is there a way to add memory to the Roku?
There doesn't seem to be screws in it to take out and open up the inside.
