In short, i have to keep cloning one of my Pc's mac addresses.
Question is why??
First i have comcast. Second: i have a linksys cable modem. Third: I have a WRT54G using both wireless and rj45 connections.
Wireless unit is about 3 months old, up until 2 or 3 days ago everything was fine.
Than it started, could not connect, "FINDING SITE" is all that was displayed, well a little quick troubleshooting told me that the wireless router was to blame. After trying ALMOST everything under the sun, linksys said try cloning one PC's mac address, and that worked.
For about 1 day. The problem has happend again twice, both times cloning the mac address works.
I have 2 Pc's and a wireless laptop, besides that, nothing has changed.Nothing that should matter anyways. One thing that has changed and i will change after this writing is that for added security, besides data encryption for the laptop, i added each pc's mac address into the routers configuration and told it to limit connections to only those Mac addresses.
Maybe i am stupid, but this should not cause the problem im having.I had it configured this way for 2 weeks before the problems started.Now every day i have to clone that mac address.
Help
