Also, I should add, if I can't find a repeater that'll play nicely with the MN-700, any suggestions for what manufacturer makes a good repeater friendly replacement? Is there a really good access point/repeater pair that's better than the competition? I wouldn't be opposed to a higher powered access point that might either eliminate the need for a repeater, or at least the need for a dual antenna repeater using a directional antenna for one of the antennas (I think SMC is one of the companies that makes a higher powered unit). That being said, first & foremost, if I do replace the access point, I want one that's done right - I hate it when I buy something just to find out there's a bug in the unpnp, or that there's some other stupidity either in lack of / or poor design of features. For example, given the price competition for access points they're many times cheaper than a simple repeater, yet some access point makers don't design the ability to configure it as a repeater.
