Is there any means (cable and fittings available) for moving the antenna from a Linksys WMP54G Wireless adapter and putting it on top of the CPU box instead of behind it? I am getting a weak signal on that computer, and I think the main reason is that the CPU box is shadowing the adapter's antenna.
This computer is downstairs from my gateway, and about 60 feet horizontally removed from the gateway. Unfortunately, the downstairs computer has to face toward the gateway, putting the adapter's antenna behind and in the shadow of the metal CPU box.
I would like to find a small base and the necessary cable to put the antenna on top of the CPU box and try it that way. Have any of you ever done this?
