when using WPA (pre-shared passphrase) my laptop fails to reconnect after standby. Using manual disconnect/reconnect also fails - a reboot is always required.
The laptop will find the wireless network and indicate a connection (Speed etc.), but no transmission is possible. I can't ping my router (which works as the Access Point)
The problem doesn't occur when not using WPA. Also I've not experienced this problem with other laptops.
The Hardware: Router (AP): SMCWBR14-G EU The router is not acting as a DHCP-server, all IP-addresses are indicated manually. Laptop: Toshiba Tecra A3 (101)
Thanks in advance Ryan Dahl
