Hi everybody, I just purchased a D-Link Rangebooster G PCI card, model number WDA-2320. Hardware version is A1 and firmware version is 1.00. I selected this particular card because I thought that "rangebooster" meant it would give me a higher signal percentage as well as longer range, but apparently I thought wrong. Replacing my old D-Link DWL-520 (not plus), which gave me an average signal strength of 11 mb/s "good" or "low" using the Windows XP's Wireless zero-configuration service. With the "rangebooster" card, I am getting 54 mb/s speed, but signal strength fluctuates between "low" and "very low." Can anyone offer an explanation for this? The PC is in the exact same place, as is the router. The antenna is positioned exactly the same as it was previously, and other than the fact that I've put in this new card, nothing has changed. Any advice would be helpful.
Thanks in advance,
-Hukuis
