A neighbor asked for some help in setting up their network and getting some upstairs computers networked to the WAP/Router located in the den.... a Dlink-615 -
Everything was already setup by their son, and should have worked ok - except for the den computer which still had the PPPoE client prior to purchasing the WAP/Router.
Anyway - I like to start at the least common point and build, so I turned the router from b,g,n to just b/g - And was thinking..... of RF signal coverage vs flat out speed, since the end connection is a 1.5mbit DSL line.
I was wondering the ramifications - ignoring compatibility - of choosing the different "modes" for the WAP...
SO - how is a b/g setting vs the b/g/n mixed mode setting I seem to recall some interaction in mixed modes, but can't remember if it was related to B/G or the N mode.
How do the different modes effect range ? What about going 20mhz compat vs 40mhz channel ?
Basically just thinking of all the "choices" in a real world situation where the "range" or "reach" of the WAP is probably more important than a local LAN speed demon, since the end connection is only a DSL line of 1.5mbit...
