I've got the following set up....
WAN | ADSL Modem with 4 port wired Router | | | PC1 | D-Link Wireless Router | USB Wireless adaptor | PC2
For some reason my D-Link Router is unreliable. It works well after switch on but within mins is becomes painfully slow to surf the web on PC2. PC1 is fine and so is the wireless link it seems.
The thing is I haven't got time right now to investigate so I'd like to replace the D-Link Router with a cheap wireless access point so that in effect PC2 is connected straight into the router in the ADSL Modem.
Is that possible?
Colin
