I have a Netgear 802.11b wireless router. I have one computer connecting successfully using a Netgear MA111 wireless USB 802.11b adaptor and this works fine. I am now connecting a second computer using a Netgear WG111 wireless USB 802.11g adaptor. All indications are that the WG111 connects to the router fine. I receive the solid green light and the Smart Wizard indicates a 100% signal. However, when I attempt to access the Internet, I get "cannot connect to server". Now the odd thing is that if I connect to the Internet using the wired connection and then plug in the wireless adaptor and remove the wire, it will maintain the internet connection and access successfully.
I am using Comcast as an ISP and running Windows 98.
Is there a setting that I am missing?
Any assistance is appreciated.
Thanks Lou
