I have a very simple network at home with a Linksys WAG54G router, a couple of PCs connected to it via Cat 5 cable and a wireless networked laptop with a Belkin 54G wireless PCMCIA card.
Everything works fine, except when I try to do anything with security. So, the first thing I try is to have the router not broadcast its SSID, but as soon as I do that the laptop cannot connect to the network at all, no matter what I do. Does anyone know why this is and what I might be able to do to make it work?
Thanks,
Charlie.
