This is a very basic question but perhaps there is a registry hack or something or CMD file I could run. Appreciate replies, advice
Set up a used laptop for my daughter. It is an IBM Thinkpad.
I have a wireless network. Works fine.
If I plug laptop directly to router via Ethernet then I found I have to inactivate (disable) the Wireless connection for the Ethernet to work. Else wireless is still operating.
Is there a better way around this, perhaps command file to click on turn on or off wireless on laptop?
Thank you Patty
