I am aware that some people use Airlink AWLL3026 with Linux but is it for Linux only? I tried using it on an XP box and I didn't see any network. Tthere should be a few on this block - I have seen them on a laptop.
I tried uninstalling (using uninstall shield as well as the other way) but I am still seeing it under "Add/Remove " program but now, I don't even see an option for "Wireless Network Conenction" under "Network connections".
Is this product incompatible with this XP pro box which is Dell P 4
1.4 GHZ? This desktop has has no spare PCI slot for me to put PCI wireless card.
