Has anyone swapped out the internal Broadcom wireless card and replaced it with an Intel card in a HP DV8000z notebook? The DV8000z is the one with an AMD Turion64 cpu.
I'm having a devil of a time with the Broadcom 4318 card that comes installed in the DV8000z and Kubuntu. I can get it to work most of the time, and when it works it works well, but it's a pain to continually fix it after some small update or change.
I'd like to swap it out for an internal Intel card and be done with tweaking.
If someone has done this swap, what Intel card did you use?
