I'm behind a router that provides NAT, so all my internal addresses are
192.168.x.x. When I look at the WAN address assigned to my router (in the router's config utility) it shows what looks like the dynamically assigned public IP address from my ISP (24.x.x.x). However, if I bypass my router and connect my computer directly to my cable modem, my computer's IP address is NOT the same number as that listed in the router config. It's a completely different number, such as 66.x.x.x.What's going on there?
jm
