I am not sure if this is the correct newsgroup for this query, please advise if not!
I have an ADSL modem-wireless-router and wish to print, from my wireless enabled lap-top to a remote printer. Sending an ethernet cable or an USB cable is not really practical in this location, which raises the question, is it possible to link to the remote printer, a conventional ink-jet with USB, fitted with a cheap USB wireless stick?
I realise there are wirless enabled print servers but this seems to be rather an expensive overkill, if USB means what it says on the can, i.e Universal!
