Dear All,
I have a Belkin F5D7632uk4 adsl router. I have set up my network to use WPA-PSK authentication with TKIP encryption. All works well between my router and desktop (which has a belkin card), however, my laptop (using Intel Proset wireless) is fine when I first log on to the network but if I turn off my laptop and then turn it back on later it seems to connect but does not get authenticated and hence cannot communicate with the other machines/ or internet.
If I switch to using 128-bit WEP everything is fine. Does anyone have any suggestions (is 128-bit WEP secure (I can pick up a couple of other nearby networks))
Thanks in advance,
Martyn
