Hi
I'm using Xp and IE6.
Suddenly I have to re-enter the password every time I want to connect.
Instead of connecting as normal, I have to open the wireless connection... then open View Available Networks, then put in password again.
Another PC in the house has no probs with the wireless hub.
This happened suddenly.
I don't connect using the Belkin software that came with the modem on my PC, teh HUB is a D-Link wireless, I'm just the Windows Network Connections which worked fine before.
Any ideas on how to fix this?
Many thanks
