We just moved our internet service from Earthlink DSL to SBC DSL. The new DSL modem (a Netopia router with 4 ports) is up and running and plugged into our existing 8-port Linksys Router.
Everything connected to the Linksys router works as it should. That is, the computer with a shared folder is accessible by the other 3 computers that are also plugged into the Linksys router. Also, these 4 computers can all access the printer that is plugged into the Linksys.
Now, the problem I have is, if I disconnect one of the computers from the Linksys and plug it into one of the Netopia DSL Modem's ports, this computer can no longer see anything on the Linksys router (i.e. it can't see the shared folder, nor the printer).
Can anyone point me in the right direction to get this computer to see the others. If you can even tell me what I need to be doing I can do some further research from there and come back with additional questions.
By the way, the modem is set up with a static IP address for internet access. And, all computers can access the internet regardless of which device they are plugged into.
Thanks for any help.
