I've had problems with the above units failing to maintain a DSL connection - the 'internet' light simply goes out or goes red. When it works it's fine, but after a period it just drops the connection, and while it can sometimes be cycled to force a reconnection this doesn't always work.
I've used the hardware on different ADSL lines with different hardware connected, but the result is always the same. All 5 of a batch that I bought in the UK in November 2005 have displayed this problem
- does anybody else have similar experiences to share?
I'm an engineer/reseller, BTW, so I'm looking at hardware/firmware issues, rather than basic configuration tips.
TIA
Peter
