I just switched from Comcast to Bellsouth DSL. I am using a 802.11g Netgear wireless router. Every thing worked fine with comcast but now with Bellsouth, I stop getting a wireless signal every few hours. If i directly connect the Belsouth router to the desktop/laptop using ethernet cable then every thing is fine but as soon as i rewire every thing through the wireless router, I can only surf for few hours and then i stop getting a connection. some times, i lose the connection after few minutes, some times, i lose it after three/four hours.
i was with bellsouth tech support twice and they had me reboot every thing and got the wireless working but of course, after few hours, i lost the connection again. it is very frustrating to go reset the routers ever few hours. any help will be greatly appreciated.
