I have a Netgear FWG114P router. I'm trying to make it reach to my daughters mini Mac only 20 feet away.. The reception is really good though the house, and I believe that her computer unfortuenly, sits in a bad spot, and the signal is weak at her desk.
I went and got a Apple Airport extreme unit to route around the bad spot. And use it as a WDS. Seams like it would work as it just relays the Internet thought it.
I can set it up and log into it via a wireless connection. But when I try to get the unit it log into the base station (Netgear).. It simply just refuses to do it!!
I've tried unlocking the WEP password, and still it refuses??
I routed a temporary eithernet from the router to the AP extreme unit, and it works..
Checking the Netgear web site, it doesn't show the FWG114P router as a WDS compatible.. Others say this though.
Is the FWG114P WDS compatible?
Thanks
-Richard
