Hello all, this seems like the appropriate place to ask this, so I hope you can help. For some P2P features in an online game, I am required to forward port
2350.So I enter the range 2350 to 2350, set it to both TCP and UDP (as required), enter the correct IP address, enable it, and save the settings.
However, it doesn't appear to work. The port test located at
I've heard horror stories about v5 of the WRT54G, but most everyone I spoke to had nothing but praise for the v3 model.
So, I did what anybody would do in this situation, I upgraded the firmware to the latest version. (v4.30.5, Apr. 27, 2006) Yet the problem still occurs.
Does anyone have a solution for this, or will I need to contact Linksys? This is the only problem I've had with this router and don't feel like shelling out MORE money for a replacement.......
