OS: Windows XP SP2 NIC: Linksys Wireless-G PCI Card Router: Linksys Wireless-G Broadband Router
I moved the Wireless PCI card to a different PCI slot (on the same PC) as I installed a WinTV card in its place. When I rebooted the machine the networking wasn't working so I had to reinstall drivers and reconfigure. But it won't work with WPA encryption enabled. When I disable all encryption it works fine (NIC receives data from router) but when I enable it and it gets its IP, the NIC stops receiving data from the router (e.g. 16 sent and 0 recieved in Connection Status screen).
I tried rebooting router, reinstalling NIC & drivers, resetting router, creating new passcodes, nothing. All the other wireless clients on the network work fine.
Any fix that saves me from formatting?
TIA
