I purchased the WVC54G camera to replace my WVC11B model which is working fine.
The camera was set up exactly like the WVC11B so I know it was correctly configured and my network is correctly configured for port forwarding etc.
The camera works using the internal IP or the WAN IP/port as long as I am inside my network. From outside I can not connect. Again the WVC11B works fine so I am positive there is a hardware or software problem causing this. Linksys support confirmed that it should be working and suggested I exchange the device. I decided to return it instead since I really thought it was a software issue and not hardware.
Is anyone else having this problem ?
Is anyone using the WVC54G successfully from outside their own network ?
There is a new Firmware 2.07 which may address this issue however linksys support can't explain to me what was fixed in the firmware version. If anyone else is having this problem and is willing to try this firmware I would really appreciate it if you let me know if it works.
