My wireless card is picking up all available networks and seems to be working fine, however it cannot get an IP address. I went to command prompt and when typing IPCONFIG I get the following error: __________________________________________________________ Windows IP Configuration An internal error occurred: A device attached to the system is not functioning. Please contact Microsoft Product Support Services for further help. Additional information: Unknown media status code. __________________________________________________________
Additionally: No error is listed in the device manager and in network connection the wireless appears as "Connected, Firewalled"
Icon on tray shows activity, but no connection is available to the network.
I tried the command "netsh winsock reset catalog" and it did not work (I thought it did for a few moments!!!)
Now I just noticed that if I plug a cable to the Ethernet adapter and run "IPCONFIG" both the wireless and the ethernet have an IP, although the wireless is getting a 192.168.1.xxx and it should be a 192.168.0.xxx. As soon as I take the cable out, the error message above appears when I run IPCONFIG.
Thanks in advance.
PA
