Hi -
I have a problem with the port forwarding page in the setup for the dlink dsl g604T adsl modem router.
I can use other pages on the 10.1.1.1 site - for the router - but cannot use the advanced - port forwarding page.
I doubt if i am the only one who has this problem - but I would like to be able to save or edit ports.
When i try to edit or add or delete a port forwarding entry I get an error message like:
char :1 error : object expected, code : 0 URL: http://10.1.1.1/cgi_bin/webcm?getpage=../html/advanced/adv_vritualserver.htm&var:rule=0 but i cannot do anthing about this with ie browser settings. Dlink tell me it is a microsoft problem - but i am not sure - i think that the firmware may be bugged. I think that i will need to reset and re-install the firmware.
Any advice appreciated.
Doug
