Problem accessing website from inside network
Thanks for all your replies. The conclusion here seems to be there is no way I can configure my router to direct to the different sites from intranet using the regular URL. Feasible solution for me either I have to use LAN IP(s) or configure Apache to direct me to different sites based on VirtualHosts.
Thanks Sachin
shahsachin
One way was valid on the Intranet that was given is to go configure you HOST file on the machine that allows you to apply a IP to an URL such as
to 192.168.1.105 as an example. The O/S looks in the HOST file first for URL to IP resolution before it goes out to the network to obtain the information from a DNS server,which in your case was being equated the WAN IP from your ISP that the WAN on the router is using because it was hitting the ISP's DNS servers on the URL lookup.
Duane :)
Duane Arnold
