According to an electronics sales person, Windows allows for the disabling of Wi-Fi cards, which ensures that it draws no power. I suspect that as
long as the card is inserted, there will always be some power, and the most sure way of eliminating power drainage is remove the card.
Is the power difference between disabling and removing a card neglegible? What about the ease with which disabling can be done from Windows 2000? Is it a pain, or is there a system tray item to do this?
Is there a difference in power consumption between cards for 802.11b and
802.11g? Or is the difference overshadowed by power differences betweencard models for the same standard, or between different manufacturers for the same standard?
Thanks,
Bernie
