power save options on D-Link DSL-G604T
Threaded View
I have had a problem with my d-link, this is the e-mail a posted to this
group
Ever since I got my D-Link G604T I have trouble.
When I turn on my computer everything connects with no trouble, but some
times when I leave my computer on for some time and then go and try to
connect I can't get on. Other times I can connect, this has me baffled.
Has anyone got any ideas?
firmware for d-link V1.00B02T02.UK.20041126
I am new to this side of the Internet, before this I had the frog and it
was just p&p with few errors.
Also I can get into the d-link settings pages at any time with no
problems, when I check the settings it comes back saying everything is
connected and the log shows there's no problems.
I have the microsoft firewall switch off and I'm using zone alarm as my
firewall..... the firewall on the d-link is enabled???
please help
I've contacted my ISP and they've said that it's more than likely the
router settings..... The idle time settings or the power save mode....
I have looked in the set up pages for the d-link but I can't find idle
time settings or power save settings..... does anyone know where they
are for the d-link DSL-G604T.
cheers
I hope someone can help me with this???????
Re: power save options on D-Link DSL-G604T
I just installed one, haven't changed any settings other then what's
necessary to log in,
router stays connected. You could try the factory reset and start again.
Is your laptop / computer powering down the wifi adaptor when left idle ?
In any case clicking on the network icon should re establish connection in
seconds.
Regards,
Martin
Martin² wrote:
thanks for the reply.
it's my main computer connected by a network card, I have the power down
option for the network card switched off..... I have tried the factory
reset but no good
I also have all the power save options switch off...... I have the new
drivers for the d-link but I don't know if they are any good.
Site Timeline
