Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Adam Chapman on April 18, 2008, 5:58 am
Please log in for more thread options I'm looking at splitters to use on my small aircraft which has two antennas broadcasting video data. I'm new to RF stuff, could somebody please tell me what 'power pass' means and what it causes to happen? I'm looking at splitters similar to the first two at http://www.rgsplit.com/servlet/the-Splitters-cln-Power-Pass/Categories, but if anybody knows of a lightweight option that would be great. Regards, Adam | |||||||||||||||||||||||||||||||
Posted by Pen on April 18, 2008, 11:37 am
Please log in for more thread options Pass I believe means the devices will pass DC power to down/up stream devices. I would think, unless you're dealing with extremely low powered transmitters that something like these would be more appropriate. http://www.instockwireless.com/power_divider_2way.htm | |||||||||||||||||||||||||||||||
Posted by LR on April 18, 2008, 12:40 pm
Please log in for more thread options Adam Chapman wrote:
> Hello,
Most of the small quality dividers are not cheap.
> > I'm looking at splitters to use on my small aircraft which has two > antennas broadcasting video data. > > I'm new to RF stuff, could somebody please tell me what 'power pass' > means and what it causes to happen? > > I'm looking at splitters similar to the first two at > http://www.rgsplit.com/servlet/the-Splitters-cln-Power-Pass/Categories, > but if anybody knows of a lightweight option that would be great. > > Regards, > Adam http://www.ssejim.co.uk/rfpowerdividers-2a.htm The ZAPD-4 sma that is listed may be worth a look. Weighs 170 gms Data Sheet:- www.minicircuits.com/pdfs/ZAPD-4+.pdf | |||||||||||||||||||||||||||||||
Posted by Adam Chapman on April 27, 2008, 10:52 am
Please log in for more thread options > Adam Chapman wrote:
> > Hello,
> >http://www.rgsplit.com/servlet/the-Splitters-cln-Power-Pass/Categories, > > but if anybody knows of a lightweight option that would be great. >
> > Regards,
> > Adam >
> Most of the small quality dividers are not cheap.http://www.ssejim.co.uk/r= > The ZAPD-4 sma that is listed may be worth a look. Weighs 170 gms
> Data Sheet:- > =A0www.minicircuits.com/pdfs/ZAPD-4+.pdf thanks, this one http://www.minicircuits.com/pdfs/ZAPD-4+.pdf is nicely sized but rather heavy still for my application. Is the cast aluminium casing used for shielding? if so would it be possible to remove the case and replace it with RF absorbing foam? | |||||||||||||||||||||||||||||||
Posted by DTC on April 27, 2008, 11:14 am
>> Adam Chapman wrote:
>>> Hello,
>>> I'm looking at splitters to use on my small aircraft which has two >>> antennas broadcasting video data. >>> I'm new to RF stuff, could somebody please tell me what 'power pass' >>> means and what it causes to happen? >>> I'm looking at splitters similar to the first two at >>> http://www.rgsplit.com/servlet/the-Splitters-cln-Power-Pass/Categories, >>> but if anybody knows of a lightweight option that would be great. >>> Regards, >>> Adam >> Most of the small quality dividers are not
cheap.http://www.ssejim.co.uk/rfpowerdividers-2a.htm
>> Data Sheet:- >> www.minicircuits.com/pdfs/ZAPD-4+.pdf >
> thanks, this one http://www.minicircuits.com/pdfs/ZAPD-4+.pdf is > nicely sized but rather heavy still for my application. Is the cast > aluminium casing used for shielding? if so would it be possible to > remove the case and replace it with RF absorbing foam? | |||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| power pass splitter | April 18, 2008, 5:58 am |
| RJ45 splitter for Ethernet - possible ? | March 28, 2008, 11:56 am |
| Can a non POE switch pass POE? | November 2, 2005, 2:26 pm |
| WAP with DHCP Pass Through... | July 1, 2006, 12:22 pm |
| WPA PASS PHRASE COMPATIBILTY | March 30, 2006, 4:06 pm |
| Re: 802.11n Draft Fails to Pass | May 4, 2006, 5:41 pm |
| Re: 802.11n Draft Fails to Pass | May 4, 2006, 6:24 pm |
| Help with alvarion administrator pass | January 24, 2007, 7:11 pm |
| Netgear ME 102 pass word needed | March 23, 2005, 10:12 pm |
| How to enter Dlink DI-624 without pass..problem! | May 25, 2006, 8:38 am |
| Forgot Pass and Username for Linksys BEFW11S4 | August 26, 2006, 5:06 pm |
| Linksys WET11 does not acquire or pass DHCP addresses | July 17, 2006, 12:50 pm |
| Antenna power? | January 10, 2005, 10:04 am |
| 802.11a power amplifier | May 5, 2005, 9:56 pm |
| APs with 802.3af Power Over Ethernet? | February 5, 2006, 11:37 am |
power pass splitter
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Regards,
> Adam
