Hi Everyone,
I've got a Linksys non-wireless router with a few PCs plugged into it sharing an ADSL connection. The router handles NAT, all that good stuff.
I'd like to plug some cat 5 Ethernet cable into the router and connect a wireless access point to the other end of the cable, about 75 meters away, to provide wireless coverage to a 3-4 laptops.
Is this as simple as it sounds? Or is there something I'm overlooking? Presumably the second access point will also use NAT, so we'll wind up with routable IP NAT NAT... Is that going to be a problem? Is there a specific product I could connect to the end of the cable that would address these issues?
Thanks in advance.
Geoff Glave Vancouver, Canada
