I have an HP Laptop (Compaq nc6120) which has integral Intel Centrino wireless and I also have a Cisco 857W Router.
OS is Windows XP SP2. I am using WPA TKIP.
On one occasion I noticed that the wireless performance was poor and a set the dot11 interface as follows:- speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0
The PC is 10 feet from the AP, line of sight is unobstructed.
The issue:-
I have now noticed that the ping time to the router over the wireless link was sometimes concerningly slow.
I have now noticed that the different behaviours occur depending on whether the Laptop is connected to the mains or running off battery.
Here is what I see:- The #### indicate that the power lead was removed or re-connected. I flagged a couple of interesting reports with #.
Reply from 172.18.46.1: bytes=32 time=1ms TTL=255 Reply from 172.18.46.1: bytes=32 time=1ms TTL=255 Reply from 172.18.46.1: bytes=32 time=1ms TTL=255 Reply from 172.18.46.1: bytes=32 time=1ms TTL=255 Reply from 172.18.46.1: bytes=32 time=1ms TTL=255 Reply from 172.18.46.1: bytes=32 time=1ms TTL=255 #### Reply from 172.18.46.1: bytes=32 time=18ms TTL=255 Reply from 172.18.46.1: bytes=32 time=18ms TTL=255 Reply from 172.18.46.1: bytes=32 time=18ms TTL=255 Reply from 172.18.46.1: bytes=32 time=12ms TTL=255 Reply from 172.18.46.1: bytes=32 time=16ms TTL=255 Reply from 172.18.46.1: bytes=32 time=18ms TTL=255 Reply from 172.18.46.1: bytes=32 time=18ms TTL=255 Reply from 172.18.46.1: bytes=32 time=1ms TTL=255 # Reply from 172.18.46.1: bytes=32 time=18ms TTL=255 Reply from 172.18.46.1: bytes=32 time=18ms TTL=255 Reply from 172.18.46.1: bytes=32 time=17ms TTL=255 Reply from 172.18.46.1: bytes=32 time=18ms TTL=255 Reply from 172.18.46.1: bytes=32 time=1ms TTL=255 # Reply from 172.18.46.1: bytes=32 time=18ms TTL=255 Reply from 172.18.46.1: bytes=32 time=18ms TTL=255 Reply from 172.18.46.1: bytes=32 time=18ms TTL=255 Reply from 172.18.46.1: bytes=32 time=1ms TTL=255 #### Reply from 172.18.46.1: bytes=32 time=1ms TTL=255 Reply from 172.18.46.1: bytes=32 time=1ms TTL=255 Reply from 172.18.46.1: bytes=32 time=1ms TTL=255
I have tested pinging to 127.0.0.1 and the address of the PC's wireless card 172.18.46.201.
In these cases there is no change to the reported RTT which is
