I've now built several different antennas for the wi-fi. The dish works very well and about the same, as far as signal strength goes, but better in noise rejection is a "Cantenna" I think that they called it. Basically just a tube, calculated as a wave guide, with a radiator
1/4 wavelength from the closed end.I'm not sure whether this is what you were recommending as there is also a "Pringles Can" that uses reflectors and directors inside the tube.
However, the recommended length of the "Cantenna" seems to be one wave length. Which is about 8 inches. Because of what I welded together to make the tube mine ended up 12 inches long, about 1.5 wave length. Dom you think cutting the tube to 1 wave length improve signal strength?
Secondly, I am now getting greedy. Since the Cantenna and the dish each worked very well, thank you, I'm now thinking of combining the two. If I do that I am assuming that the mouth of the tube should be at the focus point of the dish? right?
Cheers,
Bruce (bruceinbangkokatgmaildotcom)
