PCMCIA with external antenna
Anyone know which pcmcia cards can use external antenna's ? I need to try and get a better signal at my laptop docking station and can't add a pci card to it.
Thanks
Raceman
The Proxim Orinoco 8470 has an proprietry external antenna connector. They also do the "range entender" antenna.
Cheers.
Emlynfluff
Buffalo WLICBG54S
But you are better off with a USB or Ethernet wireless access point, where you can position the unit for best transmission/reception. There are significant losses in external antennas, and improvements are minimal, especially with a long cable.
SMS
Instead you could attach a wireless device with a better antenna to USB. Some time ago I experimented very succesfully with a Sitecom WL-012 Wireless Network USB Adapter.
There must be many similar (11b and g) device available.
With the wireless USB adapter you can establish a connection with any
802.11b compatible wireless network. The USB adapter is plugged into a PC or notebook having a free USB port. The wireless USB adapter can communicate directly with another wireless network card in an ad hoc network or it is hooked into a wireless network featuring an access point. If in a wireless network use is made of several access points, this wireless USB adapter automatically chooses the strongest signal (roaming).
C> Anyone know which pcmcia cards can use external antenna's ? I need to
Eric P.
I don't think you meant to say "USB or Ethernet wireless access point" What you want is a USB or Ethernet Bridge to connect to the docking station. There are lots out there, just depends what you want to spend.
If you still want a card Senao makes a strong one with an external antenna connector. Check ebay.
DS
Yes, I should have said USB adapter or wireless Ethernet converter.
SMS
