This is sketchy info, but please give me your best guess.
Was using a 2dBi rubber duckey whip to pick up a signal about 20 degrees off it's peak angle and getting a "fair to good" connection, good enuf for my slow purposes (using a laptop and very good senoa pcmcia card). Signal was improved about 5-10% with a home made, cut in half tin can placed behind the whip a few inches to act as a reflector.
Moved to new apartment about 3 miles further away. Still getting the signal at about the same angle, but too weak to be stable.
New choices for better antenna are a flat panel 14dBI antenna adjustable indoors around a swivel pole or a 12dBI Yagi which, by virtue of it's shape and size appears to be more easily adjustable. A cursory look at the specs seems to indicate they both have about a 40 degree signal pickup horizontal field.
I know nothing about the signal transmitter or antenna, except that they are broadcasting on channel 11, so little or no interference as rest of scanned transmitter points are all on different channels. And it is not encypted and my guess is that it is a school.
Which am I more likely to get a better signal with, the Yagi or the Panel?
Here is a weak diagram of my best guess of the location of the transmitter and my antenna. Distance is about 3-4 miles. The transmitter is likely up high since I am picking it up from so far away.
TX- - - - - RX(receive)
Here are the antennas I am looking at to possibly boost my receive ability.
Yagi:
