I've been searching for a pair of wireless headphones that could be used with an AV system as a simple wireless stereo headphone, but that could also be used with my computer as both a headset as well as microphone (presumably using a USB dongle). So far, I've found one or the other, but nothing that sounds like it would work well for both. My computer use would be primarily for listening to music and dictation anthough skype or similar would be a possibility.
One other complication is that I am moderately hearing impaired, so a headset with lots of volume (and preferably tonal adjustment) would be a great help. Yes, I can use my aids, but the distortion sometimes becomes unbearable, even with wired headphones.
Any takers?
IF I'm in the wrong place, I'd appreciate a pointer to the right group.
Thanks,
Bob
