Does anybody know of an other-than-trial-and-error method of maximizing signal strength for a wireless router. The only choices I can think of is getting a larger antenna (it's a Linksys router, for which I've seen add-on antennas) and, maybe, playing around with orientation of the antennas. That leaves changing the channel, which was set, by default, I guess, to six. One of the remote computers shows "low" signal strength, while the other, about
10 feet closer to the wireless router, does not show "low" signal strength.- posted
18 years ago
