Hello group,
First of all, apologies if this is the wrong group for this message - it did seem the *most* appropriate one.
I have a Belkin wireless router that died on me several months ago. True to their word, Belkin kindly arranged a replacement under their lifetime warranty but said not to send the deceased one back to them (no LEDs were lighting at all, even though tests showed the power transformer was working correctly).
So, long story short is that I would like to open the case and see if there is any tinkering that can be done under the bonnet. This is just for my own interest and not to try and fleece Belkin.
The trouble is, the case is pretty firmly fixed to the base and although it is worthless in its current form, I am very reluctant to make any destructive changes to it (for now). I would even like to avoid cosmetic 'screwdriver' marks if possible.
Does anyone *know* of a method of opening these up without causing damage? I imagine there must be some kind of clip that snaps in place when they are manufactured.
Thanks for any advice group,
Martyn (not neo).
