Hi, I am trying to use a Dell True Mobile 1150 series PCMCIA wifi adapter in my XP-running laptop in place of a USB Linksys 2.4Ghz.
The Linksys works great. Swapping it for the True Mobile I get the message that I am connected, signal strength is Excellent, I have reentered the WEP code and all seems great. Except that I cannot get access to the INternet. All the standard pages I go after "fail".
I have compared the properties of the two adapters when installed and they seem virtually identical. IP Address in the 192.168.2.xx range, gateway is 255.255.255.0
snipped-for-privacy@aei.ca (peter) wrote in news: snipped-for-privacy@posting.google.com:
You say the card is using a static IP or a DHCP IP of the router. Can you ping any of the sites with the new card at the Command Prompt? If this is IE you're using, did you clear out the Temp Files out of IE that can be holding old pages?
Hmm, I am not great at this. I think the card is using DHCP IP of the router. I can ping this IP address 192.168.2.4 successfully AND ping the router 198.162.2.1 but when I try to ping a website (ping
it fails.
when I swap adapters and use the USB adapter, I can ping an outside website successfully.
You can determine if you have a good connection on a machine by entering IPconfig /all at the Command Prompt and look at the DNS IP(s) the ones indicating that the machine has a valid Internet connection and is communicating with the IPS's DNS (Domain Name Server). You can compare them with the machines that have a good Internet connection as opposed to the wireless NIC you indicate has an IP from the router but no Internet connection.
Thanks. The results of the IPCONFIG instructions look (to me) virtually identical. Except that connection 12 below connects to the INternet and connection 2 (the TrueMobile card) does not.
You'll notice the DNS Servers IP(s) which are pointing to the ISP's (insightbb.com) servers and are not 192.xxx.xxx.xxx IP(s) Private Side IP (s) of the router. That's a valid connection that I know about.
The IP(s) for your connection are Private Side IP(s) of the router and are not pointing to the ISP's DNS Servers. Without the connection pointing to the ISP's (Domain Name Servers) IP(s), the computer -- /the O/S on the computer will not be able to resolve URL(s) like
to Microsoft's public (www) IP and the computer cannot make contact with any site, because there is no DNS on the network to use and do an URL to IP look-up to resolve the www IP.
I don't know how you're getting what you're getting. I think you need to look at another machine on your network that has a valid connection with the ISP and look at the IP(s) with IPconfig /all.
