Hello, I have an old NetGear network card for my laptop. 100Mbps. It's uses a PCMICA interface connected to a RJ45 dongle. It's IEEE
802.3u compliant. I now would like to use it to go wireless. My questions are:
1) Is there an external antenna that can plug into the RJ45 jack on the dongle?
2) Since it's only 802.3u compliant how to get to 802.11g? Is there a kit (cheap) that will enable this?
Again, no. You're trying to make apple pie with oranges. Your current network adapter card is designed for use with wired networks only. If you want to use radio waves, you'll have to buy an adapter with a radio in it,
To #1, no.. that's wired ethernet only to #2, does your older laptop have a usb port and what opsys does it run? (if usb and win me or later, usb dongles are under $40)
So let me see if I got this right. If I have an old laptop with a built-in Ethernet rj45 jack in the back, I can just plug into a wired network. To work at wifi hotspots I need another network adapter card.
I see bluetooth usb dongles on ebay for like $10. Is that all I need or do I need more? I'm running an older os, win2k server. do I need wifi software or does it come with the bluetooth usb dongle?
Erm, no, bluetooth has nothing to do with wifi. And do yourself a favor and pickup the card from a local retailer. If it doesn't work properly then you don't want to get stuck paying for return shipping. Fleabay is not the place to be 'learning' what works or not, you'll waste far more money than makes sense.
No, I don't think you have it straight. Your statement here is different from your statement in the original post.
0> It's uses a PCMICA interface connected to a RJ45 dongle.
That wouldn't be a built-in jack. That would be a PCMCIA card, with a dongle, that you suggest could be connected to some other widget to go wireless.
From an Ethernet port, either built-in or your card/dongle combination, you could plug in a wireless client adapter, but those are far more expensive than a new card, and would be large and unwieldy.
Others have suggested that you pop out the PCMCIA card and put in a new
802.11g card in its place.
Bluetooth would be a different thing altogether, most commonly used to connect to a cellphone for contact synchronization, maybe internet access via a cellular data plan.
You didn't say you had USB. You didn't say if your USB is 1.1 or 2.0 speed, you didn't say what OS you have until now. There are USB dongles for 802.11g, maybe still some 802.11b. The "b" might be in the $10 range, and would match the speed of an old USB 1.1 port. The USB-802.11g adapters are more in the $40 range from retail outlets, and USB all operate on USB
Go with a USB wireless G dongle to make sure that you are good for some time. Due to being low down on the side of the laptop, PCMCIA cards are generally not as good reception.
Here's a good list of adapters:
Check the ratings before you buy!
I prefer ones with external antenna connectors as they are more flexible, but they cost more. This one is my quick pick:
802.xxxx is merely a standards group that works on getting Ethernet packets transmitted across different physical media
802.3 = wired ethernet via RJ45 (either built-in or PCMCIA card)
802.11b/g = WiFi - common wireless access - again a PCMCIA card with the WiFi electronics bluetooth - a "personal" area network... like cellphone to headset or PDA to laptop again - a different technology requiring a different PCMCIA card with different electronics
now - the physical choices.... PCMCIA card to slide into the laptop slot for WiFi, bluetooth, Ethernet RJ45 or the USB dongle solutions for WiFi, bluetooth, Ethernet RJ 45
Win2k Server might be a problem - you need to have the driver software for the specific card, and Win2k (server) support might be a challenge for some of these...
Hmmm. Maybe so, I don't know, but otoh, his PC slot is probably not used for anything else, and his USB port might be needed for a memory stick or something. My laptop is old, but the PC slot and the USB jack are about the same height, on opposite sides.
If you are inclined to email me for some reason, remove NOPSAM :-)
