NSA spying: What's the best phone encryption & IMEI random number generator? - Page 2
Threaded View
Re: NSA spying: What's the best phone encryption & IMEI random number generator?
On Sun, 08 Sep 2013 20:10:16 -0700, Jeff Liebermann wrote:
Hi Jeff,
Ah. I knew you knew what you were talking about, since I know you.
So I'm glad you clarified. I never think about Verizon, since I'm
a GSM person nowadays. So what you're saying is that, for CDMA
telcos, they *need* the IMEI to verify the account.
But, for GSM telco's, the IMEI is a (nearly) meaningless number
from the standpoint (only) of identifying the account.
The IMEI, as you noted, is certainly a predictor of the telephone
capabilities though - but that's not the reason for my concerns so
I won't worry about data plans and software upgrades.
My Android phone isn't rooted (and I'm not really sure what that
even means) so, my first order of business is to figure out how
to ROOT the Android phone. Then I can worry about installing
the terminal emulator. And then I can change the IMEI.
On T-Mobile GSM, do you predict any negative repercussions from daily
changing the IMEI number (assuming I generate a valid IMEI number)?
I wouldn't say meaningless because if your fone is stolen  and you
know the IMEI they can block any fone with this EMEI from registering
on to their network.  Of course there is nothing stopping them from
going to another GSM / WCDMA carrier and  using it unless there is a
common stolen fone database running between carriers..
Such databses exist between carriers in some countries, but I don't
think there is an international shared database of stolen phones.
Casper
The record will show that, at least in the USA, the carriers have
absolutely no interest in blocking stolen phones.
They won't do anything - as you can see from mine and other posts.
So, from _that_ perspective, the IMEI is a meaningless set of numbers.
I a number of countries in Europe, they are being forced by the
government.
Casper
It does seem that GSM IMEI numbers are more meaningful in the UK and in
other European countries (and India, I believe, based only on anecdotal
information from friends) than in the USA.
But, in the USA, GSM cellphones are so plentiful, I guess, that the two
key GSM carriers don't do a thing if you call them to tell them yours was
stolen. Nor does one of those two GSM carriers ever care what IMEI number
you are using (from their service standpoint).
So, the point is that randomly changing IMEI numbers every day (which is
the stated goal) should have virtually no meaning to my GSM carrier (T-
Mobile), so, if I accidentally goofed up, and created an IMEI number that
turned out to be from a stolen phone, nothing bad would happen (AFAICT).
The only thing I'm not sure of is whether something bad would happen if I
had the dastardly bad luck of choosing an IMEI number of a cell phone in
the same cell as I was currently in.
Would *that* IMEI then cause a problem?
Or, if you had the bad luck of choosing an IMEI number of a cell phone that
the NSA was targeting by a drone -- just to bring it back to the Subject:
Good point!
This response made me laugh, as I had NOT even thought of that!
The non-removable batteries are also a potential trojan horse as they
still might provide tracking power even if the phone is supposedly
turned off.
You have a point here. No vendor runs their batteries down to zero. It
is bad for the battery for one thing. Then if you undervoltage lockout
scheme isn't foolproof, you can brick the phone. This has happened with
some Windows phones, though I forget which brand. [Probably not Nokia
since they have excellent engineers.]
Oh, they care, all right. And you should care too, if you think you'll ever
want the SIM subsidy code (or SUK) (for unlocking the phone to work with
some other carrier's SIM) -- for the SUK is found in a look-up table the
original carrier has, with key entry being the handset's factory IMEI.
And, actually, far more plentiful than GSM handsets in the USA are the CDMA
handsets that Verizon, Sprint, and their resellers, provide: such handsets
don't have 15 digit IMEI strings, they have alphanumeric, hex or dec MEID
strings (that you *cannot* pry out of the phone with a *#06# key sequence).
HTH. Cheers, -- tlvp
Avant de repondre, jeter la poubelle, SVP.
The feds (I forget which flavor) are talking about cracking down on
stolen phones in the US as well. You can google "apple picking". But the
deal with apple phones is they can also be parted out due to a constant
need for spare parts.
Maybe it is me, but I have an eye for people using iphones with cracked
screens. Or maybe I attract them. Or maybe there are a lot of people
with cracked iphones. That and broken home buttons.
You can get new Apple iPhone parts out the back door from the same
vendors that supply Apple in China.  PCB's are another story.
Considering the difficulty of repairing the PCB's, I would expect
anything I buy "used" on eBay to have a fair chance of not quite
working correctly.
Believe it or not, but it's the FCC that's "cracking down" (or more
correctly, "cracking up").
<http://www.pcmag.com/article2/0,2817,2402830,00.asp
<http://www.ctia.org/media/press/body.cfm/prid/2170
That was about 18 months ago, and predictably, nothing useful has
happened.
<http://www.attpublicpolicy.com/privacy/protecting-your-device-protecting-your-information/
    ... this summer, we’ll be launching a database that will enable
    us to identify and disable stolen devices using a unique device
    identifier called IMEI and share that info with other GSM
    carriers so any stolen device will be disabled on our network.
Note mention of AT&T using the IMEI number to disable the phone.
You rang:
<http://www.11junk.com/jeffl/pics/repair/slides/Iphone4-cracked-screen-01.html
There's an interesting story here.  I found the iPhone 4 in the gutter
in downtown Boulder Creek, CA.  It had been run over by numerous
vehicles, resulting in the rather artistic display.  I could have been
evil, installed a replacement digitizer, and sold the phone.  Instead,
I needed a karma recharge, and decided to perform an un-natural act
and return it to it's owner.  I plug in the cable, and run iExplorer
on my PC.  That gave me the phone number, address book, and the call
history.  The 2nd to last called number turned out to be a mutual
acquaintance who gave me to the owners daughters phone number.  I
eventually talked the owner and arranged to return the phone.  It
seems the owner and his wife had both undergone hip replacement
surgery and really needed the phone to coordinate rides.
I offered to fix the phone for the cost of parts ($30) plus about 30
minutes labor ($40) but the owner indicated that he had insurance from
Verizon.  So, I returned the phone with the cracked display.  Only
then did I looked up the terms of the Verizon (Asurion) iPhone
"replacement" insurance.
<http://support.verizonwireless.com/support/features/calling_features/equipment_protection.html
$10/month with a $169 deductible.  The replacement phone is
refurbished, not new.  I can buy a used iPhone 4 on eBay for about
$250.  He's been paying the $10/month for over 2 years or $240 so far.
In effect, his replacement iPhone 4 just cost him at least:
  $240 + $169 = $409
which is hardly a bargain.  It would have been better and cheaper if I
had replaced the digitizer for about $70.
Jeff Liebermann     jeffl@cruzio.com
150 Felker St #D    http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann     AE6KS    831-336-2558
Yeah, insurance on phones is a bad idea. By the time you break one, you
can buy one on Craigs. Remember that you need to insure the phone is
paid off.
I am assuming whatever iexplorer is can't work on a locked phone.
Yep.  Several years ago, I found an iPhone 3G that had 1 month left on
a contract.  Verizon refused to activate it, even if I paid off the
remaining month of someone elses contract.  They consided my offer to
be reasonable, but their computer had no way to accept a payment on
someone elses account.  No clue if it's still the same today.
<http://www.macroplant.com/iexplorer/
Correct.  You need the passcode.  The iPhone 4 that I found didn't
have the passcode set.
However, there are always work arounds and bug exploits:
<http://www.wikihow.com/Bypass-iPhone-Passcode
I am looking up douche bag in the dictionary. Ah, it says "see cellular
provider."
Seriously, like you can't take over a contract? I mean there is still a
credit check.
I only use Blackberries. You need to unlock the phone and the PC
interface. Apple never got their 140-2 rating. Somehow Android managed
to get fips rated. Their security is dubious at best.
It never occurred to me to use the emergency mode of the phone, but it
makes sense because that is the one thing that isn't locked.
Mostly correct.  In theory, the GSM vendor would not need to know the
IMEI number.  Reality is quite different:
1.  The SIM card identifies the owner and stores his data.  However,
if the phone is vendor locked, it ties the SIM ID to the IMEI,
effectively making it impossible to move the SIM card to a different
phone.  A less draconian vendor lock looks at only the vendor, model,
and service provider parts of the IMEI, and just locks the SIM to
those numbers.  That allows the dealer to replace one smartphone, with
a similar model, and not have to update the SIM.
2.  The IMEI defines the maker and model of the phone, and it's
features.  If those demonstrate that the phone is a smart phone, the
vendor tacks another $30/month onto the bill for data service, even if
it wasn't requested or ordered.  I did this by accident.  I picked up
a basic phone that someone had hacked with the IMEI for an iPhone 3G.
I didn't recognize the problem.  When I activated the phone for a
customer, I found a data service charge tacked onto their bill.  The
phone wasn't worth hacking, so I just changed to a phone, with a real
IMEI number.  However, the $30/month didn't disappear from the online
billing summary until after I called customer service three times.
I don't do T-Mobile, so I have no idea what might happen.  Sorry.
That is not correct: the firmware in the phone checks whether the
SIM is from a particular operator; it is locked to the operator
and not to the SIM card.
Interesting.  It is probably listed in the "small print" but that would
also mean that the operator will frowned upon change IMEIs.
Casper
On 10 Sep 2013 08:35:14 GMT, Casper H.S. Dik
True.  There is no processor on the SIM card so that comparison has to
be done by the phone firmware.  However, my point was that the vendor
lock can be by the specific phone, by the cellular vendor, or by the
phone manufacturer, depending on how much of the IMEI number is used.
<http://en.wikipedia.org/wiki/SIM_lock
 - Mobile country code (MCC; e.g., will only work with SIM issued
   in one country)
 - Mobile network code (MNC; e.g., AT&T Mobility, T-Mobile, Vodafone,
   Bell Mobility etc.)
 - Mobile subscriber identification number (MSIN; i.e., only one SIM
   can be used with the phone)
Apple and AT&T were the first to require a mandatory data plan.  If
you activated an iPhone, you were required to have a data plan.  Since
there were few protests by those who didn't want the data plan, the
other vendors did the same thing almost immediately.  I complained on
the Verizon support site, and soon found both my postings and account
had been removed by VZW.  After about 6 months, Verizon extended the
mandatory data plan to newer smartphones, eventually dividing their
selection between "feature phones" and "smart phones".  Again, there
was little protest, so the other vendors did much the same thing.  The
Verizon MVNO's were more flexible and would activate smartphones
without data plans, so all was not lost.  However, this wasn't to
accommodate disgruntled users, such as myself, but rather because
Verizon would not allow the MVNO's to use their latest data service.
For example, Page Plus Cellular will only do 3G data, not 4G.  Before
Verizon built their 4G system and only had 3G, the MVNO's could only
use EVDO or 1XRTT.
However, soaking customers for a mandatory data plan wasn't sufficient
for VZW.  They often billed customers for accidental use of the data
service.  In the early days of smartphones, it was not unusual for
customer to not know that their phones had internet data service, much
less how to use it.  If I bought a smartphone with data capability,
but didn't subscribe to the monthly data plan, I would be charged some
rediculously high rate for moving a few bytes if the phone decided to
do a lookup or update check.  Many phones had no obvious way to
disable data service. Intitally, VZW also obfuscated the charges on
the bill and didn't properly explain the charges when the phone was
activated.  That resulted in lawsuits and FCC action:
<http://www.phonedog.com/2010/10/28/verizon-settles-with-fcc-will-cut-customers-a-52-8-million-check/
The continuation and expansion of the mandatory data plan was
allegedly a result of this action.  Never mind that it would have been
trivial for VZW to block all data traffic by IMEI and be done with the
problem.
T-mobile took the opposite idea. Well sort of. They cuts the minutes
down to nothing (100 min), but added a decent data plan (4G, but only
half at the full LTE speed), the rest at their crappy 4G, all for $30.
The T-mobile 4G would be fast enough, but the latency is noticeable.
Easily over 100ms. LTE is simply amazing. About 35mbps down and 15mbps
up with no discernible lag.
Site Timeline
