Noob questions
Hello, don't know much about wireless yet, so can someone please tell me if these are possible:
1) I want to connect a (normally) *wired* IP ethernet camera to a wired router about 80m away clear line of sight. Is there a pair of wireless dongly things I can plug into the lan sockets of both to take the place of the lan cable?
2) Similar setup, but connecting a bog standard normally wired USB webcam wirelessly to a computer. Again, the wireless link serving the same function as a USB cable.
I know one can buy wireless cameras and routers, but I just want to replace the cables with wireless dongles type things that plug into the back of the original wired gadgets instead of the cable. Suggestions please?
markzoom
On 8 May 2007 01:51:05 -0700, snipped-for-privacy@digiverse.net wrote in :
Sure. You want a point-to-point bridge. Cable a wireless access point to the wired router; cable a wireless Ethernet (client) bridge to the camera; and setup the wireless connection.
Not AFAIK. You'd need a wireless Ethernet (client) bridge with a USB port and a webcam driver, which I don't think exists.
Other alternatives:
  • Powerline networking
  • Phoneline networking
  • Coax networking
See wikis below for more info.
John Navas
Many thanks! Checking it out.
markzoom
