Even though WinXP Wireless connection box says I'm connected when I open IE or FireFox browsers I get "page cannot be found". My hardware is a Dell Inspiron 8600 laptop with a PRO/Wireless LAN 2100 mini PCI card and Linksys WRT600N router. All drivers for my laptop have been updated. After spending an hour with Linksys tech support I am still unable to connect wirelessly, but my wired cable connection works fine. Any suggestions would be great because I am really fed up with this $200 WiFi router purchase which for 2 days now has not worked. Below are 2 IPconfig results, wired and wireless.
****************************************************** These is my IPconfig /all result when I'm wired to the Linksys router:Windows IP Configuration
Host Name . . . . . . . . . . . . : Eli
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Intel(R) PRO/Wireless LAN 2100
3A Mini PCI AdapterPhysical Address. . . . . . . . . : 00-0C-F1-15-E3-7E
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom 440x 10/100 Integrated Controller
Physical Address. . . . . . . . . : 00-0D-56-EC-C7-98
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 167.206.254.2
167.206.254.1 192.168.1.1Lease Obtained. . . . . . . . . . : Friday, March 21, 2008 3:30:44 PM
Lease Expires . . . . . . . . . . : Saturday, March 22, 2008 3:30:44 PM
************************************************************** This is my IPconfig /all results when I'm attempting my wireless connection:Windows IP Configuration
Dhcp Enabled. . . . . . . . . . . : No
Default Gateway . . . . . . . . . : 68.194.64.1
167.206.254.1Ethernet adapter Local Area Connection:
