I have a simple home system with CM - WRT54g - 2 wired clients - 1 WPC54g. Fixed IP on all 3) W2K clients and everything networks properly.
Ping from any client to client results in a time out response. Pings out through WAN work properly. Is there a setting in the WRT I've missed?
WRT has 3.03 firmware and a local IP 192.168.1.1 Network DHCP is Enabled Starting IP 192.168.1.100 Clients are set to 192.168.1.101 to 103
3 days of Google has not helped.Thanks for any suggestions. M2
