Setup: eMac running OS X 10.3.9 attempting to connect to Netgear WGR614, attached via Ethernet cable to Motorola SB5101 cable modem (Comcast ISP).
I can only obtain an IP address wirelessly via DHCP when I have an Ethernet cable connected to one of the Netgear's local ports. In this scenario, my Ethernet adapter has a local IP from the router of
192.168.0.2 and my eMac's Airport Extreme card gets an IP from the router of 192.168.0.3 - everything works fine and I can access the Internet.However, there is no need for me to connect to my router in this manner; I only had the Ethernet cable running to the router because I was doing setup. Once I remove the Ethernet connection between router and machine, I am unable to obtain a valid IP address wirelessly from the router. If the IP is dropped, or if I try to manually renew the IP address, I pull a 169.x.x.x.
The router's firmware is up to date and I have tried restoring factory settings, rebooting, renewing the IP address, and all of the typical primary troubleshooting maneuvers.
Could it be that my router is damaged, or is it my brain that's on the fritz?
