Hi
I cant get my internet to work on the new wireless that I have installed. The connection is fine as I am able to transfer files but not hook up to the www.
Any ideas Working both on XP
Hi
If you enter IPconfig /all at the DOS Command and the IP returned is the 169 IP, The O/S timed out and assigned the IP. The 169 IP will allow resource sharing but it will not allow the machine to access the Internet, since the O/S never got an IP form a DHCP server on the network. This usually happens due to some mis-configuration of the wireless NIC or router if a router is in play.
Duane :)
